D
dconnor
Guest
Working on hooking up the home theatre system in my office / play room (Aiwa AV-D50, saving the "good" stuff for the den / living room)
& could use some help with how the cables for the DVD player should be connected....
The A/V receiver's instructions say I should hook the DVD's OUT to the A/V's IN & then run the OUT leads from the A/V to the IN on the DVD. Makes perfect sense but the problem is the DVD player I'm using in here (Panasonic DVD-CV47) doesn't have any IN leads!!!
Should I just run the OUT leads from the A/V receiver to the IN for TV?
If I hook up an S-video cable from the DVD to the TV do I still need to run RCA's from the A/V reciever to the TV to make sure I have an audio signal from the DVD through the A/V to the TV?
Also, I have a digital cable box and VCR as well... but can only hook one of them into the A/V reciever, can I run the VCR directly to the TV & stilll have it record OK? If the VCR is going to be a hassle I'll just hook it up in one of the bedrooms, but my wife wants to be able to tape shows that we can only get through the cable box.
Doug C.
Doug C.
