I'm not sure if I should be concerned, but I hear "ticks" that are magnified with a metal rod to the ear in and around the manifold.  It isn't overwhelming and is generally limited to when the hood is open...but it does increase with higher revolutions and is definitely rhythmic.  It definitely is not exhaust and has been there since the rebuild...and hasn't grown worse.
It is a full roller setup, but not solid lifters. Therefore, I can't figure out why they would make noise in the first place..but I was told before that roller setups tend to be a little noiser....again, it doesn't make sense to me. The only thing that I can think of is that when the engine was put together the builder had one lifter that "stuck" and had to be torn down and cleaned. After that, he said it pumped up fine and wasn't a problem.
So, I listened to every section of the valve cover and couldn't find one area that was worse than the other...in fact, the noise seems the loudest around the front of the manifold around the temp sensor mount area.
Anyway, a bunch of rambling, but I could use some advice and I'm not sure how to break this down any shorter.
Thanks,
Thanks,
