How often do you guys purge or use test button on alky?
Discussion in 'Alcohol, Nitrous and Propane Tech' started by 3.8vsix, Mar 19, 2017 at 7:49 PM.
  1. 3.8vsix
    3.8vsix
    Expand Collapse
    May 25, 2001
    494
    0
    Offline
    Just wandering how often you guys have to purge your alky? I have to use the test button for a couple seconds or so before I nail it or it will knock like crazy. Even in the same day. Is this normal. Been like this since new. This happens even with new pumps I have installed though the years. Thanks for any thoughts!!
  2. 3.8L V-8 eater
    3.8L V-8 eater
    Expand Collapse
    Jul 22, 2006
    1,284
    43
    Offline
    Don't sound normal to me....If you purge it do a hit then do another hit shortly after does it still need purged??
  3. NY Twin Turbo
    NY Twin Turbo
    Expand Collapse
    All the good stuff.....Times 2.
    Dec 10, 2014
    1,580
    315
    Offline
    I have my pump under the trunk deck out back. On the first purge of the day, it takes a long while (8-12 seconds) before I get the tell-tale stumble.
    After that, I'll purge every so often while driving, just to make sure it's there ready to go. I don't skimp on the purge button. Especially when I spend time in traffic! My combo can build a lot of underhood heat when I'm not cruising. I'm afraid this may cause the alky to boil out of the supply lines leading to the inlet pipe. So I am extra cautious.
    Besides......I don't think it's a big deal to hit a button every now and then.
  4. NY Twin Turbo
    NY Twin Turbo
    Expand Collapse
    Dec 10, 2014
    1,580
    315
    Offline
    BTW, If I'm on the highway and do a few hits a few minutes apart, it doesn't need purging.
  5. 3.8vsix
    3.8vsix
    Expand Collapse
    May 25, 2001
    494
    0
    Offline
    Yes it does.
  6. NY Twin Turbo
    NY Twin Turbo
    Expand Collapse
    Dec 10, 2014
    1,580
    315
    Offline
    If you can't do a few hits a few minutes apart, that doesn't seem right. Do you seem to be going through a lot of alky? Do you have to fill your tank often?
    If you had a leak somewhere in your supply lines to your nozzle I guess it would be hard to tell.
  7. Grumpy
    Grumpy
    Expand Collapse
    Thread killer
    May 24, 2001
    10,576
    316
    Offline
    Hit ours every day when I get in the car. Thats it. Where is your nozzle/nozzles located ??? Yours is def not normal !!
    • Like Like x 1
  8. fast86gn
    fast86gn
    Expand Collapse
    Texas Moderator
    Staff Member
    Sep 28, 2001
    2,750
    167
    Online
    Just like Grumpy once a day when I'm in the car. No problems.
    • Like Like x 1
  9. 3.8vsix
    3.8vsix
    Expand Collapse
    May 25, 2001
    494
    0
    Offline
    I don't think I go through a lot of alky. I'm pretty sure it's not leaking.
  10. 3.8vsix
    3.8vsix
    Expand Collapse
    May 25, 2001
    494
    0
    Offline
    I have a single nozzle and it is probably 7" or so from the throttle body.
  11. gusszgs
    gusszgs
    Expand Collapse
    Dec 9, 2007
    650
    12
    Offline
    I hit mine almost every time I feel I'm going to get into the loud peddle. Habit really, but I don't hold it on for long.......... I just give a couple hits on the button to make sure the alky is right up at the nozzle.
  12. Pronto
    Pronto
    Expand Collapse
    A Lannister always pays his debts.
    Dec 9, 2002
    10,803
    630
    Offline
    Bet you have a leak. Get Julios test kit and make sure.
  13. 3.8vsix
    3.8vsix
    Expand Collapse
    May 25, 2001
    494
    0
    Offline
  14. Pronto
    Pronto
    Expand Collapse
    Dec 9, 2002
    10,803
    630
    Offline
    Good to have anyway to see how the pump is holding up. Don't want that nasty surprise!
  15. TurboTGuy
    TurboTGuy
    Expand Collapse
    Gray Beard Member
    Sep 24, 2010
    2,998
    780
    Offline
    Everytime I drive her, let her warm up. Hit the button until she stumbles a little, I'm good to go.
Share This Page
