identification please
spooky
is there a quick visual check i can do to see if my car has the hot wire kit on it before i buy one. ive owned the car since dec. the car has fuel rail pressure gauge, adjustable fuel pressure reg, and green stripe injectors(i think they are 36 lbs am i correct?). without taking the fuel pump out how can i tell if it is stock
thanks jason
Look for a fuse holder along with the sensors on the driver's side fender or a relay mounted back near the gas tank as these are the usual locations where guys mount those parts of a fuel feeder kit.
there is a relay zip tied up behind the gas tank. what are the green stripe injectors rated at and how much can they handle?
If I had to guess, I would say your green stripe injectors were 30# injectors, and NOT 36# injectors which generally have a dark blue top.
