greeneyegi
- Feb 21, 2010
The pumps on the hanger will NOT fit in the tank.Has anyone done this yet?
Did anybody have instructions? somthing that stated this?Installed a racetronix dual fuel pumps last year pumps were a tight fit to get thru but fit. Had to install float arm after pumps were in the tank.
Answer: It won't go in with the float arm installed, I use a pail of long needle nose pliers to install the arm after the pumps go through the hole in the tank. Found my email from full throttle hope this helps
Right on!!!Bought mine from from mike at full throttle speed. Not sure if if there is instructions. Emailed full throttle that was there response.it is a PITA to hook up the float arm with pumps in the tank.
Me too. I amazed myself it was a PITAI got mine in with the float on. Did it a few times so I got good at it.
well I need you to go into the float install.Answer: It won't go in with the float arm installed, I use a pail of long needle nose pliers to install the arm after the pumps go through the hole in the tank. Found my email from full throttle hope this helps
