K KevinB Well-Known Member Joined Dec 2, 2004 Mar 29, 2007 #1 Is the way I have these straps wrapped around the roll bar safe and NHRA legal? Also, can I cut the extra belt length off here... TIA!
S Silver 'T' Top New Member Joined May 15, 2005 Mar 29, 2007 #2 First pic "appears" O.K., but you cannot modify the belts by cutting off the excess, as far as I know.
K KevinB Well-Known Member Joined Dec 2, 2004 Mar 29, 2007 #3 Thanks! Where is the best place to mount the crotch strap? From the directions, it sounds like directly under the crotch area, whitch would be under the seat
U Underboost Mr. Dull Joined Oct 4, 2005 Mar 30, 2007 #4 I do know you need to weld a tab like this to keep them from walking. Attachments harness2.jpg 51.7 KB · Views: 285
U Underboost Mr. Dull Joined Oct 4, 2005 Mar 30, 2007 #5 KevinB said: Thanks! Where is the best place to mount the crotch strap? From the directions, it sounds like directly under the crotch area, whitch would be under the seat Click to expand... I just made up a bracket and bolted thru the floor board w/ another plate underneath. :biggrin: Attachments DSC01496.jpg 152.4 KB · Views: 289
2 2swoosh aka BURNRBR Joined Mar 9, 2006 Mar 30, 2007 #7 Underboost said: I do know you need to weld a tab like this to keep them from walking. Click to expand... i remembered being disqualified one time in Atco Raceway for not having that tab
