Kilduff Machine, Exterminator Ratchet Shifter
AN/GSC-52
Great customer service, made to order custom.
-Blacked out with black oxide hardware.
Can you post a pic installed and let us know what you had to do / cut / modify to make it work? Thanks!
No trees were harmed in the sending of this message, however, a significant number of electrons were terribly inconvenienced.
Yes I'll post everything. It will take a bit, I ordered a custom piece.
After 6 emails with Brian and a call. Brian made sure I was getting what I'd be happy with. He is a TB fan and a member on here. Unfortunately his TB was stolen years ago.
My plan is for a clean install with no metal cutting or welding on the car. Reversable if I take it back stock.
Can you use the stock cable or do you need to use an aftermarket one?
B&M
#80735
It's 5', which I like.
Short stock one seemed to bind, even after replacing.
