Leaks
pak86gn
The front passenger area under glovebox compartment collects water like a pond. I've had G-Bodies before and experience tells me its a hole in the firewall. This is my second T-top car though, and there is also a hole above the windshield on the frame, could the leak be blamed on that? That area is cracked and rusting fast. My question is, should I get another frame and cut the damaged one or just fix it? Ive tried looking for the source of the leak but no luck, any suggestions?
I had a Malibu that was leaking through the back window & soaking the back seat. It was rusted under the window after I took the moulding off. I had a body shop pulled the window out, cut out the rust & reseal the window. no more leaks....
I would do the same... take it to some shop and have them cut the rust out, weld a new piece back in... and properly reseal your front window.
good luck
Check seal around A/C box too.
...and the drain holes. These have been known to allow water into the passenger floorboard.
HTH, CaptRob
