Looking for ideas on subwoofer enclosure...
Discussion in 'Car Audio' started by juice247gp, Mar 3, 2017.
  1. juice247gp
    juice247gp
    Expand Collapse
    Apr 16, 2013
    7
    0
    Offline
    looking for different ideas... more than likely for 2 10s
  2. marcus jul
    marcus jul
    Expand Collapse
    Jan 6, 2015
    64
    16
    Offline
    A.K. audio makes a custom sub box for g body cars. You can find them on face book.
  3. MDavis
    MDavis
    Expand Collapse
    Oct 27, 2013
    589
    50
    Offline
    Made by atrend.
    • Like Like x 1
  4. turbo nasty
    turbo nasty
    Expand Collapse
    Goat Milk Racing
    Jul 19, 2001
    7,788
    265
    Offline
  5. Buckshot G/N
    Buckshot G/N
    Expand Collapse
    Nov 2, 2011
    177
    18
    Offline
    I would just go with a high quality 10" an amp. If you go with two 8" ,those seems to distort if you are a head banger. www.crutchfield.com have subwoofer boxes.But if possible I would go to the your local car audio store and have them build it.Also if you decide to go with your plan of installing subwoofers, if your car doesn't have the rear back seat GNX Brace,go ahead an get that installed,not only it's going to stiffen your car ,less vibration in the trunk. Good luck!!
    • Like Like x 1
  6. juice247gp
    juice247gp
    Expand Collapse
    Apr 16, 2013
    7
    0
    Offline
    Thank you for your suggestions......
  7. fast86gn
    fast86gn
    Expand Collapse
    Texas Moderator
    Staff Member
    Sep 28, 2001
    2,856
    197
    Offline
    I went with 2 10's behind the rear seat. They are from Pioneer and are a slimline design so you don't even know they are there until you turn it up lol. I did have to remove my back seat braces though I have room in the trunk for the two amps up top and no big box in the way. I don't have a pic but could take one if your interested in the look?
    • Like Like x 1
  8. LT1ThirdGen
    LT1ThirdGen
    Expand Collapse
    Jul 2, 2005
    9
    3
    Offline
    If you like 10s, mount them rear-facing in a sealed enclosure. They will need approximately 1 sq ft per sub, and typically at least 6.5" of mounting depth depending on magnet size. Use holofill in the enclosure to absorb vibration. Also, if you are okay with the look, dynamat the trunk lid- with its length on these cars, it will vibrate pretty badly. Use thick rubber washers between license plate and mounting plate to minimize the shaking.
    If you want a "stock-ish" or stealthy look, spec the box build to get you the cubic feet you need while still staying within the dimensions of the rear package tray. Mount the subs, and cover with the thinnest factory matching carpet you can find. You'll still see the outline of the subs, but you will maintain the most trunk space, have an overall cleaner install, and won't compromise sound quality.
    • Like Like x 1
  9. 1-CLN-GN
    1-CLN-GN
    Expand Collapse
    Aug 20, 2008
    270
    6
    Offline
    I plan on getting a custom 4th order box with a couple 10s built pretty soon. Its going to be ported through the rear deck to avoid the trunk rattling
    • Like Like x 1
  10. LT1ThirdGen
    LT1ThirdGen
    Expand Collapse
    Jul 2, 2005
    9
    3
    Offline
    What kind of music do you plan to listen to? Ported boxes are more for rap/pop, as they provide less-controlled cone excursion and have a slightly lower frequency range. The downside is that some of the "punch" is lost. Sealed boxes hit more "crisply" (if that word makes sense) and are more geared for rock music. Also, ported boxes have to be bigger than sealed boxes, if space is a concern for your application.
    Been building competition audio systems for 25 years- if you have any questions, feel free to hit me up.
    • Like Like x 1
  11. 1-CLN-GN
    1-CLN-GN
    Expand Collapse
    Aug 20, 2008
    270
    6
    Offline
    Don't have the experience you do but have been around car audio for awhile now and I'm a fan of 4th order boxes. Everything you stated is true but the trunk/quarter panels rattling with sealed boxes is one thing I can't deal with. I've tried adding sound deadner in the past but still had rattles.
    I listen to all kinds of music and a properly tuned and installed 4th order box does the trick for me.
    • Like Like x 1
  12. LT1ThirdGen
    LT1ThirdGen
    Expand Collapse
    Jul 2, 2005
    9
    3
    Offline
    It's tough chasing down rattles with the sheer area of sheet metal on a GN, and the fact that these are 30 yr old cars !
    • Like Like x 1
  13. precizion818
    precizion818
    Expand Collapse
    Nov 29, 2007
    863
    36
    Offline
    Is that two 12's and what box is that?
    • Like Like x 1
  14. MDavis
    MDavis
    Expand Collapse
    Oct 27, 2013
    589
    50
    Offline
    2 - 10's
  15. AZMotorgod
    AZMotorgod
    Expand Collapse
    Jul 20, 2010
    126
    5
    Offline
    Here is what we did with my car. Sub and amp are behind the panel.
  16. juice247gp
    juice247gp
    Expand Collapse
    Apr 16, 2013
    7
    0
    Offline
    Do you have more pics.... BadAss setup!!!
  17. AZMotorgod
    AZMotorgod
    Expand Collapse
    Jul 20, 2010
    126
    5
    Offline
    20170408_185047479_iOS.jpg 20170408_185625107_iOS.jpg 20170408_185635146_iOS.jpg 20170408_185642383_iOS.jpg
    Juice-
    Sorry, I sold the car. These are the only ones I have. It should not be hard to duplicate by a halfway decent radio shop though...
    #17 AZMotorgod, Apr 20, 2017
Share This Page
