ls 4.8 twin turbo build
87buickracer
2000 4.8 engine
2008 rod and pistons
new cam bearings
New rings and bearings
rings gapped for boost
zo6 camshaft
ls1 heads and intake
Pac 1218 springs
80 lb injectors
66mm turbos
fmic
th 400 transmission
fti converter
built rear moser axles c clips
3.23 gears
2002 ss camaro computer
speed density tune
Arp head studs
moroso solid mounts
trans dapt set back plate
ls2 timing chain
ls9 head gaskets
will post pictures as build progress
Thanks. .I try to do a little on my day off..im also putting together my grand national. .this motor is going in my t type ..and the t type motor is going in the gn so I m working on two cars at the same time..
Two forklifts was used to set body on chassis with new poly bushings..chassis was sanded to the metal, primed and painted twice..firewall of body and under hood sprayed with wrinkle plus paint..body has no rust inside and out..very solid car..under car is clean like brand new. .alot of new parts came with the car which made it a sweet deal..
I like this set up..the obx headers have a lifetime warranty now..does anyone know if the welds are better and thickness of gauge?
Got the heads bolted down with arp studs and mls gaskets. .also picked up ported throttle body.
Installed crank pulley and water pump. .have to get a throttle body spacer to keep the throttle bracket from hitting the hose neck on pump..
