MAP Sensor & Temp Sensor Taps
TTipe
Snake Skinner
I'm hoping someone might comment on what I have done so far to get signals from my Hemco plenum. I have drilled & tapped a fitting into the plenum and used 271 threadlocker to seal & lock down the fitting. The threadlocker data sheet indicates that the theadlocker will withstand temps & be resistive to vibration. Have XFI users had success with this use of threadlocker? Also will the oem temp sensor survive in the plenum given the possible pressure & temperature?
