dyeager535
- Mar 30, 2008
Hi!
I guess I better explain that while this is my first post, I've been here for many years. I've got a G-body myself (Olds) and my friend owned an '87 GN until it was stolen a few years back.
I bought a big box full of GM parts, and I just discovered that apparently SOME of the parts at least are for 3.8L motors. So I naturally thought this would be the place to post them, in hopes that maybe more of the parts are as well. I don't have any way to look up what vehicle these fit. If there is a description behind them, I was able to find what they fit based on something I could find online, but we all know most part numbers fit multiple vehicles, so those are just clues. Any of the prices are what I could find online, not what I'm asking. Best offer on anything.
25532546 Timing Chain Dampeners. Penned in number on the box, but 1356634 is the number printed on it. They almost look like GM used a tool to make the contact portion flat after production...at first I thought it was from use, but these things have no oil on them, so I can't believe that. From what I found online, these are 3.8L pieces, and were linked to the GN's.
D1955 Looks like a 4 cylinder reluctor/pickup coil.
22578692 '88-95 oil pressure sender switch
1644131 Oil pressure switch, lesabre, etc. $40 +/-
1984638 BRIDGE,GEN RECTIFIER 90-94 6.6L turbo cat vin J $14.13
d1926a ignition switch $98
15013005 D1530F ELECTRICAL / SWITCH-DIMMER/MULTI-FUNCTION 2002 1995 C/K trucks $41
15665282 D1802A SWITCH,ENG OIL PRESS '81-85 C/K truck $12
25036555 SENSOR,ENG OIL PRESS GA '88-78 A/G-body $17
25519224
10201489 350/454 oil pressure sender truck $50.
14078902 15-8218 RELAY,FAN CONT '89 Vette, etc.
2032085
10467208 D1929A MODULE,ELEK IGN CONT '87-92 FWD, Fiero, etc $132
15954529 D1547D SWITCH,I/P & INTR LP DIMR '95-85Astro, S10, etc. $12
10205676 Oil pressure D1808 (may not be that part number, but it is a sub for it) sender/switch $32
15043231 Day time running light module, $15
10244496 Oil seal, SyTy, $2
12551589 Oil filter adapter gasket $.57
10172754 SyTy oil filter pipe adapter gasket
10456288 213-324 knock sensor 2003-1985 262/350/454 etc $31
999375 Universal High Mounted Stop Lamp Assembly. This looks like a G-body third brake light to me, but in a kit form to fit the earlier vehicles.
25519224
2032085
