More Orlando Video
Will have to check this out when I'm not on a slow dial up POS computer! :mad:
Thanks for posting this :cool:
New Aluminum T/A Block w/Stage II Heads & Sheetmetal Intake
Here are some more pix of the T/A motor before installing it in the GNX.
Motor Info . . .
T/A Aluminum Block
3.625 Billit Crank
4.00 Bore
6 1/2 Rods
Sheetmetal Intake (CPP)
Stage II Heads (Flow Over 350)
T & D Roller Rockers
PT-88 Turbo
ATR Headers (modified) w/4 Down Pipe
Tail 46 Wastegate
90 mm Throttle Body
Duttwiller Oil Pump
160 lbs Injectors
Weldon Regulator
This Motor is going in a 1987 GNX w/Stock suspension. He's gonna drive it on the street. :eek: Talk about a "NASTY" grocery getter.
:eek:
Motor Info . . .
T/A Aluminum Block
3.625 Billit Crank
4.00 Bore
6 1/2 Rods
PT-88 Turbo
Tail 46 Wastegate
90 mm Throttle Body
Duttwiller Oil Pump
160 lbs Injectors
Weldon Regulator
:eek:
OOOPPPS!!! I forgot to star a NEW thread. Sorry.
Thanks for Orlando video. I didn't get to go this year.
