need help badly
Howling Mad
So I started my car today, just put in a built motor, and the O2s are going f'ing nuts at idle. Never above 300 and will drop down to damn near 0. Also the car idles around 975-1000 then drops to 600-700 and tries to stall then pics up. This does not happen at the same time that the O2s drop. Help please.
Did you try a new 02
I have one but didn't have time to run to the house and grab it. Just don't want to get my hopes up that its just an o2 sensor and then still have the same problem.
I would change the 02 as that could throw the car way out of wack, check tps and iac as well
Forged crank, scat rods, wisco (spelling) pistons, champion ported iron heads, 206/212 roller cam, billet mains(#2&3), 60 lb injectors. Any more info needed?
