Two buttons in glove box, don't know what they do I bought the car with them installed and also on passenger side a liquid filled plastic grounded to hood?
Another
If I rip out tip sensor will it cause problems?Looks like alarm stuff valet switch last picture tip sensor so it'll go off when the hood opens these are my best guess
Sent from my SAMSUNG-SM-G900A using Tapatalk
I think I'll have my GN mechanic look at it don't want it to kill my electrical but I'll look for box see what I findIt depends if the sensor is NO or NC. That's assuming the alarm still works. If the brain box is missing, you can rip out everything.
just check under the steering column and make sure you don't have a starter kill relay done there that might mess you up.
Can you explain valet Mode? I can't get over 3200rpm have to let off even 1/2 won't let me go wot that's how I got car.X 2 what Earl said also be careful how you flip or push that button with your key on you can put it in valet mode or some other mode without knowing my car was the same way ended up getting my alarm working with a battery and an alarm key fob once I found the brain
Above all you don't want to trigger that starter disable
Got it will have those guys check it out thx for the infoEvery alarm company sequence for the valet feature is different it usually involves a key on Flipping that switch one way or the other while the pressing the button a number of times will make the alarm passive but like stated above there's no way of knowing what that combo is without being there on the initial install or being an alarm experienced
