I'm attempting to install an A pillar tach.  Hookup went fine, all the connections tested out (ground, power, light) but when I tested it. Nothing happened, no needle bounce, nada.  The only thing I could see was that maybe it wasn't getting a signal from the 2 wires with the green connector behind the alternator.  So I tied into one of the wires itself, still nothing.  I took the dash out along with the factory tach. and touched the wire from the aftermarket tach to the white wire coming into the factory tach. still nothing.  Double checked the power, ground, etc. no problem, so maybe the tach is bad.
I take out the trusty 3 cylinder Geo, hooked it up and no problem, works right away.
Is there anywhere else that I can hook up to in the GN for the tach signal? Or is there a way to test if I actually have a signal at the green connector behind the alternator?
Thanks in advance
Thanks in advance
