need help quick, which ones are intake valves?
quickbrick
im doing my springs now, im just about to take them off. which ones are intake valves, cause i bought seals. and i want to make sure i know which ones i put the seals on. tia
The intake valves are the ones with seals.... the exhaust valves are the ones without. HTH
it looks like mine already has aftermarket springs. they look like the cc-980s that i just bought. it has valve seals on EVERY valve. should i take off the ones on the exhaust?
if you want to i guess. or not. btw you can always tell int/exh valves b/c they will line up with their respective runners.
