1984 t-type
Murphy's Law
- Jul 11, 2010
When I first start my car it idles rough and wants to die unless I stay on the throttle, at this time the IAC count is around 20-40 and tps is at .46. Once it gets up to temp and goes into closed loop it will idle on its own and runs a little smoother but the iac goes to zero and I cant adjust it. What could be the cause of this, bad sensor ? where should I go from here ?
