My car hates me. Here's my problems. When warm, the car will sometimes sputter away from a stoplight at barely any throttle, will sometimes sputter under boost, and will often die around right turns. It won't die around left turns, just right turns. Sometimes while going straight it will sputter a few times and try to die but it comes back. Go around a right turn when it's hot and it turns off.
Wtf? In search of this problem (I didn't realize the right turn thing until last night) I have replaced:
coil pack, ignition module, crank sensor, o2 sensor, ecu, chip. All to no avail. I have put a fuel pressure gage on the car and have seen that the pressure does not drop when the problem occurs. I have access to a scan tool but haven't used it, what would I look for anyway? Injector pulse width, maybe one is stuck?
All the GN guys I call are totally stumped. It will die around a super slow right turn as well, so I don't think it's related to centrifigal force (something swinging). Maybe something is hitting the steering column?
It's one thing after another..
