Need picture of accumulator valve sequence in valve body
PaulRV6
The accumulator body, valve and spring line up that came out of the valve body does not look at all like the view in any of the manuals I have, even the CK one. Does some one have a pic of the stock 2004R valve line up the way it should go in the valve body? It doesn't seem right the way it came out compared to all the figures in the guides I have including the CK manual. 1st one on left side with manual valve on top left. Thanks
paul
Like this one?
I put the line bias spring in the accumulator as was reccomended by several builders. And a stiffer spring in the line bias.
Maybe someone has been into yours.
#322 valve has a stem that the spring fits over, mine came apart (I think) with the sleeve first then the valve next and then the spring. Do I have the wrong valve? Any photos of this?
paul
Is it any of these?
paul
The BR Accumulator valve is at the top in the pic, the other style valve on the bottom is what is in most pictures and diagrams.
Yes David, it is the top picture. Which end does the spring go in? I think Mine came apart with the spring in the valve body then the valve (pointed end into spring) then the sleeve and plug. The spring could go in either end.
The spring can install only one way, The spring goes on the end of the valve, to the left in picture. It will install as a whole assembly.
