Need to rebuild the AC compressor
Reggie West
TurboBuick.Com Supporter!
Anyone on the board rebuild the AC compressor for the Buick?
Buy the new one. Its 134 compatible. Rock Auto has it for $166.
If you want to attempt it yourself I watched a video on YouTube on how to disassemble and rebuild.
Over the years, Delco has made about 1/2 dozen refinements to POS original compressor, and other aftermarket units are far superior to the original.
I put the 4Seasons compressor on mine on the recommendation of my local car A/C shop. Low defect rate (near zero), and it's quiet. When it cycles on, it barely hits the motor. Until I tweaked the idle control, the engine would actually flare when the compressor kicked on, because the idle-up was too aggressive for these new compressors.
With a new condenser and a 134a charge, I have 38 degrees at the dash outlet in 90 degree weather.
So yeah, don't bother rebuilding the original. It's not worth your time.
