Ok I switched to a different Style shift bracket. I reinstalled the Tv cable and the Cable rachetted only one click out. (before it was about half way) BUt now I get a lazy 2nd gear shift. It will not shift into 3rd until 40 MPH. I did recently have an incidient where the governer sping had fallen out and had reistalled since then. My questions are could this spring fallen out again and how often does this happen (200r4) . Or is it just the TV cable is that sensitive? Need help bad Daily driver. Also is there a way to check the Pivot and pull of the Cable? I switched to a Older GM throttle body and used a factory braket off the same car?
