no start... no service engine light???
sick GN
Put new turbo, and new injectors on the car.. had the computer disconnected... Put the new chip in and turned the key on... service engine light flashed then stayed on... car fired for one second then nothing... turned key off then back on and now no service engine light at all... what did I do??
Pop the chip back out & make sure its not crooked or something like that. Also dbl check orange ecu wire connection
Keeps popping fp/inj fuse... replaced inj harness and now the light is back off... Is there something that has to be reset? I did get it to come back on and it fired briefly but blew the fuse so it died... then the service light will not come back on
check over the injector harness to make sure u dont have a shorted injector wire on the harness
Ok fixed the fuse problem... the old oil sensor line was hitting the block... got the car started... but still no service engine light... checked the bulb for it also... it works... why isn't the ses light coming on?
