- May 28, 2001
Have a 59K 87 engine w/ a knock. Engine has good oil psi, low leak down, new valve springs.. Otherwise totally original. Knocks cold and warm, at idle.
Oil psi is 60-70 cold, 35/40 warm, at 850 rpm. pump is done w/ the Earl Brown mods, PTE turbo saver.
Flex plate is not cracked. Balancer is GTG, and tight. No ft accessory noises.
Pulled the filter, and cut it open...Very fine sliver dust. Drained oil, filtered it, more silver dust.
Pulled the engine, and found what I call trashed bearings. Appears to have some acid corrosion , and dirt ingestion marking. {POOR maintenance, IMO}
I pulled the pistons, re-torqued the rods w/ the brgs in them, and made some measurements.
These measurements are w/ a snap gauge and inside mic. I also have a dial bore gauge, and will remeasure all w/ that.
Using the high side of the factory tolerances:
#6 Vertical 2.2540-2.2495 = .0045
11 & 4 o'clock 2.2522-2.2495 = .0027
2 & 8 o'clock 2.2510-2.2495 = .0015
I also checked the #5, as the noise appeared to be towards the rear of the engine.
Vertical = .002
11/4 = .0015
2/8 = .0017
I've not measured any others, as of yet.
I am seeing weird wear patterns on the brgs shells. On some, the parting line clearance appears to be some 3/8" from parting line to wear pattern. # 5 & 6 brg shells fell out of the caps when I took them off.
There is no evidence of cap walk, or fretting on any parting surfaces. The main caps fit very tite in the registers. I checked the TIR on the crank main journals. <.0005.
Will have more measurements, crank journal measurements, pics, tomorrow.
Given the loose #6 brg, and the "oblong" condition of the brg, NE1 have comments as it being the probable source of the noise?
Thanks for looking....
Vertical = .002
11/4 = .0015
2/8 = .0017
