M Matt Sando Member Joined Jan 13, 2005 Sep 18, 2005 #1 lock up keeps going in and out on the highway...any ideas???
C chris718 Active Member Joined Dec 10, 2002 Sep 18, 2005 #2 is this in 4th gear at steady throttle?what if you use d3 on the hiway?
M Matt Sando Member Joined Jan 13, 2005 Sep 18, 2005 #3 this is in forth gear. it will go into lockup but after driving a while it goes in and out and RPM's go up and down.
M Matt Sando Member Joined Jan 13, 2005 Sep 18, 2005 #5 yes i forgot to mention that i have a caspers stand alone harness w/a VSS module. maybe there is something wrong with the VSS module.
