Oil leaking from transmission cover?
GNbythebay
I have e a small engine leak and I can not locate where it is coming from. I brake cleaned everything clean to see where the leak is coming from and it is dripping off the transmission cover plate. I know it's oil and probably leaking down to land I that transmission plate but what could be leaking near that area? I took a picture hope it helps.
Oil can and will leak at the front of the engine, runs along the pan rail and exits at the converter cover.
