On Center Build questions
Discussion in 'Stage II Tech' started by dank GN, Nov 30, 2013.
  1. ek02
    ek02
    Expand Collapse
    Jan 31, 2008
    919
    61
    Offline
    I grind à taper on the threads of the cam side bolts so no matter where the bolt ends up they will clear the cam. My rod bolts torque to 70 ft lbs using the old moly ARP lube. The torque is probably more like 75 with the new lube, which I don't like as much as the old moly lube.
  2. dank GN
    dank GN
    Expand Collapse
    always something
    Jan 11, 2009
    2,171
    165
    Offline
    I'm mocking up my alt bracket . Looks like I'm going to make something to adapt my impala 140amp to work with this bracket . The rods have been ground to clear the cam as well as the block to fit the stroker . I tourqued them all to 70 ft lbs IMG_8337.JPG IMG_8342.JPG
  3. Reggie West
    Reggie West
    Expand Collapse
    TurboBuick.Com Supporter!
    May 28, 2001
    1,919
    160
    Offline
    I can make you an unregulated 200 amp out of the stock alternator. Let me know.
  4. dank GN
    dank GN
    Expand Collapse
    always something
    Jan 11, 2009
    2,171
    165
    Offline
    Just Alil update . I got the short block assembled with all the head studs installed as well as the gear drive set strait up . I am now assembling my heads hopefully I will be firing her in acouple weeks IMG_8469.JPG IMG_8465.JPG IMG_8412.JPG
  5. Reggie West
    Reggie West
    Expand Collapse
    May 28, 2001
    1,919
    160
    Offline
  6. dank GN
    dank GN
    Expand Collapse
    always something
    Jan 11, 2009
    2,171
    165
    Offline
    Okay she is together I'm just waiting on some 7.900" push rods . I have every size but the size I need . Every build I've done required a new set of pushrods fml . Anyway she is looking good and can't wait to get her in and fired up :) thank you guys for the help and answering all my dumb questions . IMG_8500.JPG IMG_8555.JPG IMG_8557.JPG IMG_8521.JPG
  7. dank GN
    dank GN
    Expand Collapse
    always something
    Jan 11, 2009
    2,171
    165
    Offline
    Okay today I finished my crossover pipe to make these headers work . I got the drivers side from a friend and the passenger side from another friend so had to fab up a crossover pipe to make them work . IMG_8583.JPG IMG_8589.JPG IMG_8590.JPG IMG_8595.JPG IMG_8594.JPG
  8. rag231
    rag231
    Expand Collapse
    Apr 30, 2005
    1,055
    43
    Offline
    Darth Vader is always lurking!!!!! That's too cool!
  9. dank GN
    dank GN
    Expand Collapse
    always something
    Jan 11, 2009
    2,171
    165
    Offline
    lol I forgot I hung him up there
  10. dank GN
    dank GN
    Expand Collapse
    always something
    Jan 11, 2009
    2,171
    165
    Offline
    Okay so I finally got the right size belt 46" . I also plumed my oil bypass line into the top of the timing cover because the champion bracket wouldn't let me go to the fuel pump block off plate . I'm going to be pluming in a LS1 smog pump with -12 lines to help evacuate my crank case pressure . My pushrods (7.825)should be here by the end of the week aswell as my 7168 comp turbo .im shooting for this weekend to fire her . I'm having a BBQ on sat with all the local gn guys to celebrate this historic day lol jk . If u are in SoCal and would like to come by and have a brew and a burger hmu . IMG_8779.JPG IMG_8780.JPG IMG_8778.JPG
  11. ttypewhite
    ttypewhite
    Expand Collapse
    Oct 1, 2001
    2,905
    293
    Offline
    You actually can get to the fuel pump block off plate. The 2 aluminum 1.5" sleeves that the bolt travels threw on the Champion bracket just need to be grinded down. I did that with mine. I laid it down on a belt sander and made the circle sleeve look like a letter D. The fitting will fit in there behind the pwr steering pump with no issues.
  12. dank GN
    dank GN
    Expand Collapse
    always something
    Jan 11, 2009
    2,171
    165
    Offline
    I just ended up drilling and tapping the top of the timing cover . I placed it right by the cam sensor pointing at the top of the cam gear so I feel it's actually getting better oiling then if it was in the block off plate .
  13. dank GN
    dank GN
    Expand Collapse
    always something
    Jan 11, 2009
    2,171
    165
    Offline
  14. dank GN
    dank GN
    Expand Collapse
    always something
    Jan 11, 2009
    2,171
    165
    Offline
    Well the day has come to rig her up and drop her in . Now to start wiring her up. IMG_8872.JPG IMG_8878.JPG IMG_8882.JPG IMG_8886.JPG
    • Like Like x 1
  15. ttypewhite
    ttypewhite
    Expand Collapse
    Oct 1, 2001
    2,905
    293
    Offline
    Looking good. Do you have enough wrap on that pwr steering pump pulley? You might have a problem there with it. I know mine with a good 45% wrap gives me issues if it doesn't have the right tension to it. Especially seeing how we are spinning it using the smooth side of the belt, not the serpentine portion.
  16. turbobitt
    turbobitt
    Expand Collapse
    Feb 14, 2002
    2,211
    278
    Offline
    Yup IMO its going to need more wrap. There are solutions to this problem.
    AG.
  17. dank GN
    dank GN
    Expand Collapse
    always something
    Jan 11, 2009
    2,171
    165
    Offline
    So you are saying the solution is to fab a idler pulley and move the power steering pump up? Why would Champion sell this bracket if I need to modify it some more ? Man the intakes I've had to fix the water port on both my new champion intakes and now this bracket . I'm going to run it and see how bad it is before I proceed to modify it
  18. ttypewhite
    ttypewhite
    Expand Collapse
    Oct 1, 2001
    2,905
    293
    Offline
    Absolutely. Champion made this bracket for the purpose of being run with a stock water pump pulley configuration. With a electric water pump, your going to have to be creative to make it work as it was originally intended. The pic below shows the way the bracket was intended to be used. Notice the amount of wrap that the pwr steering pump pulley was designed to use.
    [​IMG]
  19. turbobitt
    turbobitt
    Expand Collapse
    Feb 14, 2002
    2,211
    278
    Offline
    No the power steering pump is in the same spot but the alternator is swung down to increase the wrap. The bracket was never intended to be used with an electric water pump.
    AG
    • Like Like x 1
  20. dank GN
    dank GN
    Expand Collapse
    always something
    Jan 11, 2009
    2,171
    165
    Offline
    Okay that shouldn't be a issue as I made the bracket to be adjustable . :)
Share This Page
