P/S pump pulley and
Chuck Leeper
Toxic old bastard
Staff member
the inner hose connection on the p/s box are close.
I am using a spaced out Vette accessory drive/mt so that the balancer, [F body] works, and the turbo x over clears.
The PS pulley sits directly above the fitting hole.
I see there are banjo fittings that will allow some room, but they require a flat sealing surface for the seal washer.
The ?: who has used a banjo, or has done something else that works?
Will -6 lines on both ports work?
NE1 have a source for a smaller pulley that's not the "national war debt" to buy? Something near 5 1/2" will be fine.
TIA,
