Hi
I'm looking for some guidence with this. I bought the car in the fall and really haven't driven it much since I have had it. Anyway, I bought a powerlogger and started playing with it this weekend. I did a run up to about 60 and got knock in the middle of first and all of second. KR went to 12. O2 starts at 860 and goes down to 740. It seems my TPS is a little low, but I'm guessing this isn't causing it. The boost spike was to about 19 and then settled back to around 16 or 17. I'm running Sunoco 93.
The car has a Red's 93 chip. It looks like they put on a small air compressor regulator to adjust the boost. It is a small plastic regulator that has ARO on the side of it. The vac line goes in and then looks like it just vents out on the other side. I have not touched it since I bought the car. I have a walbro 340 that I just put in with a FT hot wire kit. I adjusted the fuel pressure to 43 and varified that the FP climbs 1:1 with boost with an electronic Snap-on guage.
I don't actually hear any knock when running it. Should I hear it?
Can some one give me suggestions on what is wrong? Is it just too much boost for 93 gas?
Here is my powerlogger file for those who would like to see it. Also, I have factory injectors and they are at 150% duty? Does this seem right?
I have 60lb injectors and a TT chip, but I want to make sure the car is good before I start throwing parts at it. I would also like to take it to the track and make a basline pass before I start adding parts.
How can you post the powerlogger file? I compressed into a zip, but now the file size is a little to big. How can I make it smaller to post?
Chris
Chris
