I fixed it. The pump doesn't whine now. It was the hydroboost. Rockauto is return and rebuild only now, autozone out of stock at distribution, advance same, oriely's 7-10 days, nappa do damn expensive. I have hoses and a master cylinder for sale now if anyone is interested. The hydroboost is going back to autozone today. I was not going to have the car down another week.
Oh, the trick for the brake pedal is to take the nut off of the bolt that holds the pedal, push the bolt out, but not all the way. Then you can swing the pedal down far enough to attach the hydroboost end. I dropped the steering column down also so I could push the bolt back through. That way you don't have to take the seat out or even lay on your back under the dash. I did everything kneeling outside of the car.:biggrin:
I used the one in the writeup, which is supposed to be the '84-'85 unit and it went on my '87 perfect. As far as I know the rod is the same.
I been told they are different legnths...however I plan to get a rebuilt one from Cardone to compare to the powermaster rods....for length I assume it has the bigger hole n the end (1/2) to go on the pedal pin gizmo.
denniskirban@yahoo.com
It does have the same size hole as the powermaster unit. I bolted up the '84 Hydroboost to the firewall and the end of the rod was where it is supposed to be. If the rods are different lengths, I'd be willing to bet it is because the distance from the plunger to pedal on each unit is different, not because the pedal assemblies are different. My guess is that they used the identical pedal assembly on all the HB and PM cars. Take it from those of us who have done the swap, the rod on the hydroboost lines up perfectly and does not need to be swapped. If anything, you may need to screw in the brake pedal switches a couple turns but that is it.
You have brakes, just not power brakes. Been down that road with my Suburban(and it has the reservoir for backup but it doesn't last long). Chucked the tensioner pulley. You also don't have power steering at that point. Real bummer. Keep the tensioner, belt and fluid in good condition and you are good.I bought everything with the oem looking MC for 200.00 /Only thing anyone might consider car stalls ....no brakes... and or lose belt... no brakes....there is no reserve vacuum like the booster or PM System unless you go with the more expensive Hydroboost
If any of you guys are removing a power master I'm in need of a brake pedal
Let me know who has one
Gnxparts@gmail.com
It works
