BLACKHAWK38
- May 26, 2002
I was just wondering if anyone knows, the particulars of the pro-pain Nozzle in the OGS kit?
IS the tapped hole required 1/16" npt like a nitrous jet, 1/8" npt? straight mechanical thread, or metric 8mm.75 like the ERL aquamist?
ALSO, what would be a good orffice size
for about a 350 hp application?
Turbo Buick Cars
1985 Riviera Convertible,104k miles
Stock motor
Stock turbocharger with 60 trim compressor wheel
Upgraded Exhaust>single 2.5" Stainless straight through design with Edelbrock RPM Muffler
Random Cat(9000 series 447CFM)
Mandrel 2.5" Downpipe
Finishline ceramic metallic Coated headers and VINCE WELLING DeSIGN modified COBRA NECK 1984 CROSSOVER
87 ecm
MSD DIS-4
30 Lb green stripes
Kirban Adjustable fuel reg
Homemade fuel pump volt booster box
2400 stall Dacco 7227
rebuilt transmission with shift kit
Kenny Holmes big tube GN radiator
Flow-kooler water pump
Black-Magic electric fan
3:36 differential upgrade from 3.15
Melling HV oil pump
Remote mount oil filter (fram HP-4)Modifed Earl's billet 1578 block adapter for O- ring seal hose connectors<closer, neater fit , perma-cool filter mount, 10 AN lines DENSO heated lead proof O2 sensor
Casper's knock lite gauge
Boost gauge
Oil temp gauge
UNDER car COLD air intake filter
I run sunoco GT-100 90% of the time and can manage 20 psi boost with little knock
2ND turbo RIVIERA
1985 T-type Coupe
Still up in NJ for MERKEL 109 BLOCK roller cam motor make OVER> TA-33 turbo , ported intake, 62MM throttle body,COATED 2 inch crossover Pipe off a 1980, stock 85 pipe is a whimppy 1.5" OD , Coated headers, 2800 stall, Eirc SHERTZ transmission rebuild,Jay Carter Varible timing chip with 87 ecm, 37 lb DELPHI injectors, DeQuick adj fuel reg, Reds XP fuel pump
I know turbo
Riviera's ARE Pig slow compared to the GN, but I like EM
Turbo Buick Cars
Stock motor
87 ecm
MSD DIS-4
30 Lb green stripes
Melling HV oil pump
Boost gauge
Oil temp gauge
2ND turbo RIVIERA
1985 T-type Coupe
I know turbo
