PTS xtreme deep pan question
quickturbo
Does anyone know what filter is used with the 2004r PTS xtreme deep oil pan? I'm rebuilding my trans and I don't want to use the filter over if I don't have to. It looks like a off the shelf filter they used. I'm just not sure which one.
Mine came with a brass screen filter, in the back of my mind it is a Dodge filter, 727 maybe....
why does mine have a brass filter? should I change it?
You probably have a knock off of a PTS pan. Lots of copies out there and didn't use the same hardware.
My shallow PTS pan has a brass filter as well.
I'm not sure what the replacement filter is I just clean it once every 50K or so.
heres the filter setup that was in my pts deep pan
I too have the same setup as pacecarta and bought mine directly from Bruce back in the day. I just clean mine out with brake clean and dry it really well being careful not to hurt the filter.
Does the tube that goes into the valve body using one orange ring or 2. Can't remember
