I trimmed out the lip on the map sensor and used a compression over the nipple. Then adapter the compression fitting.. whalla..
I use the -3 teflon SS hose on my connections. XRP ends.
Pics???
I bought my fittings from Grainger. Legris was the manufacturer. My vacuum block rubs on the hood so I planned on putting a thin cover plate on the throttle body and tapping the manifold with a couple of 1/8 npt holes. I was considering a remote Vacuum block or Tee to supply some of the other items.
For me its BOV/Boost Controller/PCV/Fuel Regulator/Map/Guage/Brakes.
Aminga.. here are some shots how I did mine. Sorry for the delay :redface:
So an update. My push locks on the wastgate actuator failed the leakdown test. It wouldn't come off but was bypassing some air. Using julio's as a basis. I got some 1/4 X 1/8 NPT compression fittings from McMaster Carr. It fits on the barb on both the wastegate actuator and the MAP sensor and it seals. THen I used a 1/8 X 1/4 Pushlock on that.
I'm all converted now, Pics to follow
whos push locks are you using, mine doesnt leak
......Has anyone added any type of a fitting (compression, push lok, etc.) to the fuel pressure regulator? The nipple on my Bosch regulator appears as if it is threaded in. I'm wondering if I can remove the nipple and drill and tap as neaded for a more robust sealing connection.
Yep! Here are a few shots of the lines and fittings which Brian installed on my car. :wink: I think that they also sell this as a kit (custom-made for each customer's specific needs).I think Cottons sells a kit also.
