Where is he sourcing these? I was under the impression these are not available new. He knows it's not the same as a monte right?I just talked to a body shop about this yesterday. They said the glass would need to be replace along with the trim. The price for one was $383 and it was 2 hours labor to remove and install the new one. Driver's side will need to be done soon on mine and it wouldn't make sense to do only one side.
Yes. More information pleaseWhere is he sourcing these? I was under the impression these are not available new. He knows it's not the same as a monte right?
Sent from my VS990 using Tapatalk
If you don't find what you're looking, the shop that did some work on my car can order the quarter panels. Perhaps you can check around at collision shops, they may be able to order for you. $387 per window at my collision shop.I think have some quarter windows restored several years ago in storage. Will double check .
Can you please give, or get more specific info on this? Nobody I know of body guys included know where to get these windows. Please give us specifics I would love to know where to buy new onesIf you don't find what you're looking, the shop that did some work on my car can order the quarter panels. Perhaps you can check around at collision shops, they may be able to order for you. $387 per window at my collision shop.
Did you call? If you do and find out who manufactures these please let us all know. I intended to contact them but hadn't had a chanceThanks for the info.
This is a duh moment, I should've called since I know the people there pretty well.I'll call on Wed. and provide info to board.
I will do it tomorrow morning. I just had another car fixed there and my temperature sensor, outside air temp displayed on center console screen, isn't working correctly.You can still do that..........
That's what I'm thinking, because my temperature was initially reading -40. Probably pop the hood and see.Ambient Temperature Sensor, they probably forgot to plug it back in.
BMW's are famous for those things failing. They read -65 degrees when they go bad.
any news from this alleged source?I'll call on Wed. and provide info to board.
vader6, I called and left a message with the guy from Whittico and he never got back to me. I will give him a call on Monday.any news from this alleged source?
