WarWagon
Caustic Cacophony
- Mar 10, 2007
Thanks Guys I'm working on it. Charlie if I didn't have such a long drive back home or had trailered my car I'd have checked them at the track, all I brought were no tools lol.
Just the other day the car developed a miss under boost. I removed and examined the spark plugs lastnight. Cyl 1 and 2 spark plugs had some rust and looks like coolant seeping in. The rest looked good as expected but cyl 6 was fouled out. They all were gapped at .025 then I cleaned at opened them to .028 gap. Installed new plug wires and scraped off the oxidation on the distributor cap and rotor terminals. I decided to perform a compression health check while I was there. This engine has 200k+ miles and every cyl was 150-145psi execpt cyl 5. It was 116psi. So put it back together turned alky off set boost to 20psi and it's fine now. When the roads dry up I'll turn it back up and let the alky flow again and see where it's at now.
