Scanmaster G for Classic FAST HELP ? ---- Here i go again.
Stupid question alert
Could i wire up the scanmaster and FAST DATA logger at the same time to the one and only communication port?
Scanmaster G Version Classic 1.0
Next how do i configure the scanmaster's settings -- it displays
AFR -- looks good
Ret -- I hope it works i'll have someone tap it for me latter on
MAP -- steady on 4
Boost -- Does NOT move from -14
Target AFR -- Does not move from 0.0
Volts -- seem to be working
O2 correction -- seems to be working.
Coolant -- is way off and all over the place
Air Temp -- is way off and all over the place
RPM -- looks about right
TPS -- Volts looks about right
TPS % -- Does not move from 0.0
VE Pct --- is moving but i don't now enough to tell if its correct or not
Inj.Pw -- looks about right
