secret to removing two bolts while rebuilding stock turbo?
boredguy77
Hi, I am rebuilding a stock 86-87 Gn turbo, and Am trying to remove the two bolts that hold the turbine to the c.h.r.a, but the problem is I can`t get a good grip, and I have already rounded the bolts. anyone have a suggestion on how you did it?:confused:
moaned and complained and did it, they are a p.i.t.a but thats just the way it is
bolts
heat the surrounding area with a cutting torch being careful not to damage anything else, keep the heat concentrated, and use a good snap on flank drive wrench.
<KM>
One of mine was so bad I had to chisel the head off :mad:
