Sal Lubrano
- Apr 26, 2002
I am running a 18 volt motor off of three 6 volt SLA batteries in series. When the batteries need charging, I have to break down all the connections and change them to parallel to use my 6 volt charger. My question is can someone help me out with an idea or drawing how I can easily switch the the battery configuration with out moving all the wires. Maybe through relays or switches. Don't want this to get too complicated. If, you do use a relay it has to fail 6 volts - parallel. A perfect world would be able to hook up the charger to the motor wires and switch to 6 volts. All of my ideas are getting too complicated with diodes and multiple switches in different positions.
