Setting T P S
pitoturbo
well do you set you t p s with engine off key/on or engine at idle?it's seem to be diffrent set with engine off , 46=engine off,44=when engine is at idle. i asume with engine off key/on? what's the best way?
dont crank the engine keep the key turned in the on posistion
you should be good at.44or .46 also step on the gas pedal allthe way you should see at least 4.6 to 4.7 at wot
