tonylukejr
- Aug 31, 2002
Somethings not right with my car. Can't really explain it. It just feels like it should be alot faster than it is with all the upgrades it has. Took it to Craig at Custom radicals in atco last week and he agrees somethings not right. He said the car feels like it's doing mid 13's when it should be doing mid to low 12's ( with all the upgrades )I'm taking it in to him this wendsday hope he can figure it out.
1987 GN
ENGINE was completely rebuilt Bottom half of ENGINE completely balanced
NEW PISTONS and RINGS
NEW CAM
NEW KNOCK and CRANK SENSORS
NEW BEARINGS
NEW FREEZE PLUGS and SEALS.
STOCK INTAKE
STOCK THROTLE BODY
STOCK HEADS
STOCK REAR AXLE 3.42 GEARS
STOCK INTERCOOLER
ADJUSTIBLE FUEL PRESSURE REGULATOR
High Performance CAM SHAFT
High Performance LIFTERS
High Performance PUSHRODS
High Performance VALVE SPRINGS,
High Performance DOUBLE ROLLER TIMING CHAIN SET
High Performance HIGH VOLUME OIL PUMP
High Performance TIMING COVER
40-PSI INJECTORS
TE44C- TURBO with adjustable WASTEGATE
WALBRO 340 INTANK FUEL PUMP
3 INCH DOWN PIPE
HIGH FLOW CAT CONVERTER
3-INCH EXHAUST SYSTEM FRONT TO BACK WITH OPEN CUT OUT
2 FLOW MASTER TWO CHAMBER MUFFLERS
TRANSMISSION done by ART CARR trans has all EXTREME DUTY PARTS and can handle 850 hp.
CONVERTER IS 9 INCH 3600 STALL.
The CHIP IS THE ULTRA CHIP.
HYPERTECH 160-DEGREE STAT.
1987 GN
NEW CAM
NEW BEARINGS
STOCK INTAKE
STOCK THROTLE BODY
STOCK HEADS
STOCK INTERCOOLER
40-PSI INJECTORS
3 INCH DOWN PIPE
