The easiest way to stop this is to have the throttle stop screw moved out so that the butterfly valve doesn't snap completely shut when you let go of the pedal...regardless of the IAC reset procedure. If the valve stays open enough to allow air in, it shouldn't die. If that increases your idle speed significantly, you'll need to alter the chip...of course that what is necessary to add the infamous "decel patch" that david is referring to.
