VERY surprised that a 49 is even around any more???
bop4ever,the ta49 flows 800cfm and the te44 flows 850 cfm.both turbo's flow considerably more air than a stocker which with a few tricks can flow around 600 cfm.
With a 100% stock longblock, my car went 11.53@118 with a turbo that looks exactly like the stock turbo.
Mods?
Thrasher 108
36# Bluetops
275/60 BFGDR's
2.5" duals with ultraflows
TA49 with garrett housing an ported stock turbo bell
3 inch LS1 MAF inside of the factory airbox
THDP (it went 11.74 thru the stock Elbow)
Big neck stock intercooler (It went 11.8 thru the stock neck)
other basic cheap recipe mods on a 95K mile, un opened long block.
Three questions. How much boost? Why the 3" MAF instead of the 3 1/2? How does the thrasher compare to a turbotweak chip?
With stock head's and intercooler the boost must have been turned up near the max.I have head's and Intercooler with my TE-44 and most guy's still are lucky to run mid 11's with a similar combination to mine.Im also not into running crazy boost and 110 octane.To me I only care how the car performs on the street,for now. I can't afford blowing the engine or trans at the track.
I just care how my car performs on the street.As long as I feel the Torque and the tire's stick to the ground Im happy.At the track I would have fun but right now can't afford a blown engine,tranny or headgasket.I keep my boost at 18 lbs on the street with no problems.I jusst want to get a Precision housing and swap the Garett out.My car felt alot stronger with the Precision housing.Im going to wait for a BB Turbo unless my TE-44 starts to feel too slow for me.
YupIf you want street performance, save your money for alcohol injection instead of a larger turbo.
Larger turbos make more power at higher boost levels. It's the Boost not the turbo size that's important.
If you did take your car to the track, you would be one of those people who are shocked to see how slow it is at 18 psi with a 93 chip, even with ported heads and a front mount.
Thats probably what I plan on doing with Alky Injection.My car doesn't feel slow to me on the street with 93 octane but I can see how 110 Octane gas can change things alot.There are alot of car's that can run 11's with 93 octane gas,just not a whole lot of them.
