Taking a Stock Engine with Stock Turbo to the limit....
Discussion in 'General Turbo Buick Tech' started by murphster, Feb 16, 2017.
  1. achalmersman
    achalmersman
    Expand Collapse
    May 28, 2012
    805
    121
    Offline
    Same here. Really wish it was available.
    No trees were harmed in the sending of this message, however, a significant number of electrons were terribly inconvenienced.
  2. Mr.Spool
    Mr.Spool
    Expand Collapse
    Nov 6, 2006
    2,789
    184
    Offline
    At 3000lbs and with your knowledge of the cars I think your going to fly.looking forward to this thread.
  3. turbotroy
    turbotroy
    Expand Collapse
    Jul 27, 2012
    684
    88
    Offline
    Subscribed!
  4. murphster
    murphster
    Expand Collapse
    Feb 15, 2003
    863
    86
    Offline
    I think the car is close to 3100 right now with me in it. I've been thinking I could do a couple minor things and bring it up to 3200lbs which is a TSM legal weight for iron heads, but I'm getting ahead of myself. I'm pretty sure it would be TSM legal too, so you can use those rules as a guideline for what is done to the car. Its not like its a gutted shell or anything and the interior looks stock except for race seats. Sure there are obvious weight saving things done, but the average person would be hard pressed to see where all the weight went compared to a 3400-3500lb car.
  5. Mark T-TB
    Mark T-TB
    Expand Collapse
    car crazy from birth
    Apr 6, 2009
    284
    34
    Offline
    Lookin' forward to following your progress on this. Sounds like you and Paul will be having some fun :cool:
    Good luck with everything.
  6. bison
    bison
    Expand Collapse
    Moderator
    Staff Member
    Dec 19, 2005
    16,324
    1,190
    Offline
    Put a 150hp shot on it
    • Like Like x 1
  7. fast86gn
    fast86gn
    Expand Collapse
    Texas Moderator
    Staff Member
    Sep 28, 2001
    2,723
    158
    Offline
    Subscribed. Several several years ago went 12.0 @ 110mph on a stock Turbo, 24-25lbs of boost 25 degrees of timing, stock DP w/dump, Bluetops, Stock IC w/Duttweiler neck. I'm sure I was lean as hell. Race weight 3795 with me in it. Good luck
  8. murphster
    murphster
    Expand Collapse
    Feb 15, 2003
    863
    86
    Offline
    That's some decent power at that weight. I was in the 3600s before I started removing weight, without the spare tire and lightweight Centerline wheels. After my second pump went one time I went to a fuel cell setup a buddy had and also did front and rear fiberglass bumpers that got me into the 3400s. Never did get this car into the 11s on the stock turbo at the time (mainly because of a real inefficient converter with a bad turbo) but did take two other cars barely into the 11s at almost 3700 lbs. Was going mid 11s on a bigger turbo with all stock stuff and put a stocker back on to try for 11s and it blew apart on the track lol.
  9. smokingunz
    smokingunz
    Expand Collapse
    Mar 15, 2013
    186
    8
    Offline
    cool project, look forward to seeing your progress!
    Sent from my XT1650 using Tapatalk
  10. MCH86GN
    MCH86GN
    Expand Collapse
    Aug 20, 2008
    1,153
    34
    Offline
    Can I ask how much your vehicle weighs with driver? EDIT I found the answer, good luck.
    Good luck, I was going to attempt this years ago, but with my vehicle at 3800lbs with me in it and a TE49 with the rest stock the best I could get was 11.88 with the stock heads and IC. I had Champion ported put on after popping a gasket and I think my best was 11.70. However, I was having trouble keeping the boost at 24psi on the high end when I ran that time. I launched and was quickly at 24 psi and by the time I trapped I was at 17psi. I was using WINALDL for my data logging at the time.
  11. Wahoo
    Wahoo
    Expand Collapse
    Apr 2, 2011
    1,509
    36
    Offline
    Pretty cool thing to try. I think race gas and alky, maybe try with and without intercooler to see what helps, definitely have to have to tune right. Get a converter for that th400 from Dave husek, he made mine with the hi flow mod, I enjoy it, probably around a 3000-3200 stall.
  12. TurboBob
    TurboBob
    Expand Collapse
    Resident mad scientist
    Staff Member
    May 24, 2001
    5,699
    307
    Online
    ken white went 11.78 (I think) on a stock engine, stock turbo , stock intercooler this year.
    Bob
    • Old Old x 1
  13. murphster
    murphster
    Expand Collapse
    Feb 15, 2003
    863
    86
    Offline
    I was following him and his times. I think he's only run 1/8th mile since Bowling Green where he went 12.0. He now has the 1/8th to run 11.6-11.7 though. Very impressive for sure.
  14. forcefed3.8's
    forcefed3.8's
    Expand Collapse
    Buckey Bullet
    May 26, 2002
    3,144
    362
    Offline
    I went 11.74@114.8 with a stock turbo and engine with a powerstroke intercooler. Converter was a crappy low stall reman unit, wouldnt spool, 1.8 60'. This was at 3550lbs. The car previously went 12.0@111 with the stock intercooler.
  15. murphster
    murphster
    Expand Collapse
    Feb 15, 2003
    863
    86
    Offline
    Thats cool, seems like there are more people that have gone 11-7-11.8 than I know. 11.6 and faster seems to be rarefied air though. How long ago did you run that?
  16. seedling
    seedling
    Expand Collapse
    Jun 17, 2012
    284
    65
    Online
    This is a cool arsed thread to follow! So subscribed!!
  17. Jerryl
    Jerryl
    Expand Collapse
    Doing MORE with LESS!
    Dec 14, 2004
    7,362
    257
    Offline
    @murphster
    I realize you know exactly what to do and IMHO, it will come down to 4 things:
    Exh Drive pressure
    IC Pressure drop
    Converter slip
    Combustion pressure
    Between yourself and Paul . . . I see a record coming up. :cool:
  18. murphster
    murphster
    Expand Collapse
    Feb 15, 2003
    863
    86
    Offline
    Like forcefeds times show, I think the stock intercooler becomes a big factor because of the pressure loss across it. A good fmic with large pipes will have negligible pressure loss at that power level as some data has shown.
    For those who don't know what I'm talking about this means you may have to get 30psi at the turbo to get 25psi after the stock intercooler vs 26psi at the turbo to get 25psi after a large fmic. And better yet 30psi at the turbo could get you 29psi after a large fmic. Alky will be able to cool the intake charge so the main goal is to get as much air in regardless of temp. And a fmic has better cooling on top of it anyway.
    • Like Like x 1
  19. Mr.Spool
    Mr.Spool
    Expand Collapse
    Nov 6, 2006
    2,789
    184
    Offline
    And probably around the same race weight.i have seen race gas high timing of 30degrees and lower boost 23psi run 11.8s years age and we put together a pump gas alky that ran the same number but 30psi and 20 degrees of timing.there is the power wall where it just won't go faster and stop really gaining out the back.
  20. murphster
    murphster
    Expand Collapse
    Feb 15, 2003
    863
    86
    Offline
    I'm hoping my converter works out but we'll see... Starting off with 28" tires and my 3.23 gears will keep the rpms down on the top end. Its a lot of load down low though and prob would hurt a heavy car for sure. So if I can get out of the hole good with the tbrake and run a good 1/8th the rest of the 1/4 should be good to go... I don't even need 5000 rpm out the back if you run the numbers.
    Another thing is that XFI allows a lot more tuning vs most of the past good runs on a stock chip. A lot of people were able to maximize power by trial and error burning new chips but the feedback of a modern engine control unit allows it be done a lot quicker. I also log a lot of extra parameters that will tell me whats going on and hopefully I can make use of it and will share the data when the time comes.
    • Like Like x 2
    • Agree Agree x 1
Share This Page
