delcowizzid
newzealand turbo 3.8
- Mar 3, 2010
found this site while doing a search thought ide join up being that i run a buick engine and have turboed it.im way down the bottom of the world in newzealand down beside australia drive my aussie holden commodore which runs a buick 3800 LN3 i think it is to be exact and T700 trans.was N/A up untill a month or so ago when i built and installed a turbo setup.runing a cheap T70 with 0.83 turbine housing 0.70 compressor ,sidemount setup ,external 38mm wastegate,38mm blow off valve, 300x600x76 cooler ,39lb deustchwerks injectors,TRE performance 255L/hr pump and surge tank, 2bar map sensor and 1227808 ecu which is pretty much the same as a 1227165 USA ecu ,its also controlling boost via boost solinoid which is actually a delco remy purge solinoid for charcoal canister purge and intercooler water sprayer.its all setup with realtime tuning boards to tune it on the fly as i drive.run a naw 7S wideband to monitor A/F ratio.its a real sleeper fully stock 500000km stationwagon LOL the last thing people expect to blow them from the lights thats for sure.
