tires rims and backspacing woes
wyk3d
Car wiring sucks!
I had a set of 275/60 nittos mounted on my rims. Turns out they have 4.5bs. This is a problem as the wheels wont even turn on jack stands without rubbing. My question is this, will 3.5bs fix the problem? Is there a way to be SURE of the right size? I dont wanna buy another set of rims and have them not work either. Frame notching is not an option and i dont wanna put spacers on either. Thanks for any info.
Dan
I'm running 275/60 BFG drag radials on 15x8 3.5 bs Weld Pro Stars with no problems.
3 3/8 backspacing is too much. You want 3.5-4" of backspacing. I have 3 3/8 10" convo pros with 28" tall tires... 275's. They stick out a little, and would work perfect (no fender lip curl, no air bags) if it was 4" of backspacing.
3 3/8 backspacing is too much WRONG.......
3 3/8 backspacing will work PREFECT.......
I JUST PUT on 15X 8.5 3 3/8 backspacing With 28 x 10.5 slick, fit like a glove,
they look big, but no rubbing,
