TT5.7, TT6.1 or SD2?
Discussion in 'Computer Chips 101' started by TurboPhreak, May 16, 2017.
  1. TurboPhreak
    TurboPhreak
    Expand Collapse
    Oct 22, 2005
    10
    0
    Online
    So I am nearing the completion of my little transformation on the TR I bought last summer and would like to hear some thoughts on what route I should take regarding tuning/chip choice. The injectors I bought (used) came with a TT 6.1 chip, however it will need to be reprogrammed for the stock turbo if I go this route. I currently do not have a power logger or wideband but am thinking of purchasing them if its really the wise decision.
    The reason why I threw the SD2 into the mix is becuase my car still has the factory MAF without a translator. Is it worth it to jump to speed density at this point or will the factory MAF suffice and not kick out on me?
    Tuning wise, this is my first TB however I have been messing around with subaru's for about 6 years and am looking forward to making my setup run the best I can. (Not a set it and forget it kind of guy...)
    Car info below
    As Purchased (Last Summer):
    - 1987 Buick Regal Turbo T ~70k miles. The car is stock (even the chip :eek:) other than the original exhaust manifolds were replaced with KB "stlye" headers.
    - The car ran real good, shifted great and was a blast for the limited driving I did with it last fall.
    Build Upgrades (So Far):
    Tuning/Controls:
    - Scanmaster G
    - Boost Gauge
    - 3 Bar Map Sensor (included in my alky kit)
    Fueling:
    - 60 lb Injectors (from precision)
    - Racetronix pump
    - Racetronix pump hot wire kit
    - Acufab FPR
    - Alkycontrol Alky Kit
    - 94 Octane (Canadian) fuel
    Induction:
    - Stock Intake/ dog house cleaned up
    - RJC Power-plate
    - BGC Stretched SLIC with Dutt neck (too good of a deal to pass up)
    - Factory MAF (no translator)
    - 3" hard MAF tube with K&N cone at the end
    - Stock Turbo (will be pushed all in)
    - Boost control done via adj. WG rod
    - 3" RJC up pipe
    Engine:
    - New Comp Valve Springs
    - 160 Degree T Stat
    - New stock motor mounts
    - EGR delete
    Exhaust:
    - Old ATR 3" straight through single exit exhuast
    - 3" DP fabbed using RJC flange with large flapper and 3" SS pipe. Had to make my own becuase of the header clearance
    - 3" Test pipe
    - KB "style" headers
    Transmission:
    - Stock Tranny (looking for a shift kit)
    - Stock D5 TQ
  2. Mr.Spool
    Mr.Spool
    Expand Collapse
    Nov 6, 2006
    2,953
    203
    Offline
    Depends on if you want to keep it simple or complicate things or try to get every tenth out of the combo.the 5.7 is a nice chip with plenty of adjustments.you could also look into the axis setup from tt.me personally I like to have a wideband but not sure I would run one for a stocker combo just because it very easy to tune one off the scanmaster.the stock turbo is very forgiving.
  3. Pronto
    Pronto
    Expand Collapse
    A Lannister always pays his debts.
    Dec 9, 2002
    10,871
    639
    Online
    I'ld go with a powerlogger and the 5.7 chip to get your feet wet. You can always buy a used chip and go from there. Sounds like you have a good handle on your mods and combo.
  4. TurboPhreak
    TurboPhreak
    Expand Collapse
    Oct 22, 2005
    10
    0
    Online
    Thank you, both of you. I shot an email to Eric aswell and he was of the same opinion. It is exactly what I needed to hear. I have the habbit of getting into scope creep and trying to cover my future goals too early and dragging my projects out becuase of budget constraints.
    PS Pronto, looks like we have twins. Nice car :)
  5. TurboBuRick
    TurboBuRick
    Expand Collapse
    Moderator
    Staff Member
    Feb 18, 2006
    8,610
    308
    Offline
    Can't beat a Translator or Axis box for simplicity.
    • Like Like x 1
  6. SCOOBY DOO
    SCOOBY DOO
    Expand Collapse
    Stock Junk Rules!
    Feb 18, 2007
    1,539
    74
    Offline
    5.7 chip and a Translator is the way to fly. Can't beat it.
    • Like Like x 1
Share This Page
