VtheGNMan
- May 19, 2014
I've been wrestling with getting this new SD set up going. I have received a lot of great help from Eric, TurboDave and Dank GN.
Just one quick question. How much fuel is normal to add to one perameter before you should have changed something else to bring the baseline up? For example, if you have 80 lb injectors set and 40 Injector Offset and are adding 15% fuel at idle to get to very little correction, should you have changed something else to keep more in the middle of fueling instead of adding so much?
I appreciate any suggestions.
