turbo boost
Vsicks
hello guys i hope someone can guide me in the correct direction.
while driving at normal speeds my car runs ok. but once i step on it the turbo loses boost not sure what can it be.
What do you mean by "looses boost" when you "step on it"? Do you mean the boost doesn't come up or the boost comes up then drops off?
sorry yeah it boosts then it just lt drops off almost like the car wants to die
Go with the simple stuff first. Make sure you intercooler hoses are good and tight
If your car still has a catalytic converter, it's time to remove it, or hollow it out.
Do you have a scanmaster? Are you seeing knock or worse hearing it?
First things first.. Keep your foot out of it, til you find the issues....
ok thanks guys for your response and feedback. car was sitting for about 3 years i just got a new scanmaster installed ill check the numbers and check the hoses. no catalytic converter.
