Turbo LS Combo
Discussion in 'Turbo V8 Conversions' started by texasterror, Apr 9, 2017.
  1. texasterror
    texasterror
    Expand Collapse
    Aug 7, 2007
    248
    4
    Offline
    Hello Gents,
    I'm in the process of building a Turbo LS Engine for my T-Type. I'm trying to get an idea of what every ones combo is and in one thread. I assume it will help others in the future to have one thread with everyone's combo so they can get an idea of which route to take. Could you list:
    1) Which Block you're using example LQ4, LQ9
    2) Which Turbo (and why that particular turbo)
    3) Cam Specs
    4) Which Heads (and what work has been done to them)
    5) Fastest Quarter Mile Time (Assuming you've taken it to the track)
    6) What did you do to lower compression to make the engine more "turbo friendly"
    7) Engine Management Sytem
  2. Chuck Leeper
    Chuck Leeper
    Expand Collapse
    Moderator
    Staff Member
    May 28, 2001
    10,879
    1,011
    Offline
    Iron 5.3 out to 5.7.
    Livernois cnc /317 heads, SS/Inconel valves.
    9.2 CR, with forged JE pistons, K1 rods.
    Bullet hyd roller cam. 226/225 @ .050, LS 115*, timing @.050 I 3/43, E 52.5/-7.5, .611/.610 lift, in @ 110*
    Edelbrock 4bbl intake, Fast 4bbl t/b, 94# injs.
    Racetronix 680Dp.
    Owner built hot and cold side.
    BW S400SX3, T4, 1.25AR, 75/81, 87/81, extended tip, journal brg. About 95#/min.
    PTE w/g, HKS 50MM BOV.
    No I/C.
    Dual nozzle Alky Control.
    4L80E by Neal Racing Transmissions, PTC l/u converter by Dusty.
    9" Diff by Quicktime. 3.50 locker, Spohn arms, Viking shocks, Wolfe ARB.
    Engine mgmt by Holley Dominator.
    About it, about done, about for sale!
  3. bigmandengo
    bigmandengo
    Expand Collapse
    Aug 1, 2010
    143
    23
    Offline
    Stock 5.3 with stock heads/gaskets, plastic truck intake
    cheap 216-220 cam
    ID1000 injectors, dual 450 walbro pumps
    Precision billet 7675
    4l80e
    Stock ECU
    3900 lbs
    9.94@138
    Sent from my E6782 using Tapatalk
  4. texasterror
    texasterror
    Expand Collapse
    Aug 7, 2007
    248
    4
    Offline
    How do you like the 7675? If you could have gone bigger would you have? I'm not sure whether I want to go with that turbo or a larger turbo in the 80mm series to get the most from my V8. I don't know if the lag would be noticeable between an 80mm series and an 7675. More than likely I'm going to go with the 80mm series but I would like to get others opinions/facts. Is your turbo BB? Dude I noticed you are getting it done with a stock ECU, how is that possible? is your tranny built?
  5. texasterror
    texasterror
    Expand Collapse
    Aug 7, 2007
    248
    4
    Offline
    regarding the 75/81 snf 87/81 im assuming htose are two different turbo's. How was the lag in both of those turbos compared to one another. Also, if you could do it over again, what turbo would you use and why?
  6. bigmandengo
    bigmandengo
    Expand Collapse
    Aug 1, 2010
    143
    23
    Offline
    I'm happy with the 7675. An S480 would be awesome but I don't think the extra turbo capacity would make up for the hassle of packaging a monster turbo in the engine bay. Having an air filter and fender wells was a priority for me though..
    This 7675 lights off instantly on the 5.3 and it's a journal bearing. This setup isn't maxed out yet in my opinion. This year, the car shed some weight with an aluminum block and aluminum wheels. Also, have a stouter shortblock with higher compression. Goal is 9.50s.
    When I said stock ecu, I was referring to a stock LS ecu. It's out of a 2005 Chevy 1 ton van.
    Trans is a stock 09 4l80e with an HD2 shift kit and Circle D 2B converter.
  7. Chuck Leeper
    Chuck Leeper
    Expand Collapse
    Moderator
    Staff Member
    May 28, 2001
    10,879
    1,011
    Offline
    "BW S400SX3, T4, 1.25AR, 75/81, 87/81, extended tip, journal brg. About 95#/min."
    75/81 = compressor. 87/81 = turbine size.
  8. Vince13
    Vince13
    Expand Collapse
    Jan 13, 2010
    110
    4
    Offline
    Are you running a MAF or an SD tune on the stock ECU?
  9. bigmandengo
    bigmandengo
    Expand Collapse
    Aug 1, 2010
    143
    23
    Offline
    3 bar sd tune with hptuners
Share This Page
