L Lorenzo Member Joined Nov 7, 2006 Jan 7, 2009 #1 I have a set of stock heads fully ported and I am going to use a 210/215 roller cam. What valve springs would be good to use.
T TURBOTWIN2 ASE CMAT L1 Joined Jun 17, 2005 Jan 9, 2009 #2 No replies? What the ..... Full Throttle uses Comp Cams #26918 beehive springs in their kit. Specs are: seat load - 180 lbs.@1.800" open - 318 lbs.@1.200" spring rate - 313 lbs./inch coil bind - 1.140 HTH
